J!Extensions Store™
Re:using anchor navigation (1 viewing)
TOPIC: Re:using anchor navigation
#1195
micker
using anchor navigation Karma: 1
hello i have a little problem ... maybe not a bug maybe impossible
1 create a link in article to anchor like #accueil
2 anchor is in same page
=> scrolling doesn't work
no js error
button to top work with animation ...
do you have an idea ?
reagrds
#1196
Re:using anchor navigation Karma: 79
this probably means that the syntax used for the anchor is incorrect, you need to follow HTML like this:
<a href=" #myanchor">text</a>
and place the target element using the same id attribute without # sign:
<div id="myanchor">code...</div>
Regards John
#1197
micker
Re:using anchor navigation Karma: 1
yes your are my sunshine !
