J!Extensions Store™
Re:Add margin top to scroll (1 viewing)
TOPIC: Re:Add margin top to scroll
#1399
micker
Add margin top to scroll Karma: 1
hello how to add margin top on scrolling actualy i use it with top fixe menu and scrolling put my anchor always on top ..
thanks
#1400
Re:Add margin top to scroll Karma: 79
hello,
this should be change and added in the plugin javascript file, currently there is no settings to add a margin top
#1401
micker
Re:Add margin top to scroll Karma: 1
ok thanks
#1402
if you have some skills i will point you out
