J!Extensions Store™
Re:Modify scroll to top (1 viewing)
TOPIC: Re:Modify scroll to top
#4113
Atlanta Internet Design
Modify scroll to top Karma: 1
I would like to adjust how far the scroll to top goes. If this is javascript, I can adjust it in the cpanel if you can tell me what to look for.
#4114
Re:Modify scroll to top Karma: 78
i haven't understood what you want to adjust. However the javascript of the module is included in this file.
root/modules/mod_pagescrollbuttons/helper.php
Cheers
#4115
Re:Modify scroll to top Karma: 1
Thanks for the fast response. I have attached a screen shot which I hope will illustrate what I am trying to do.
#4117
The scroll to top by default goes to 0 using the scrollTop: 0
If you want to modify the scroll minimum value you have to work on that in the javascript contained in the helper.php
#4118
I have gone through all of the code in:
/home/atlan131/public_html/aid1010.com/modules/mod_pagescrollbuttons/helper.php and have tried several things none of which have worked. Could you assist in narrowing down the specific code you are referencing.
thanks
#4119
i was referring to the code used to perform the scroll to top till the zero scrolling, line 202
$('html, body').animate({scrollTop: 0}, $animationSpeed);
