Re:Checkbox for duplicate Sitemap Datasource is missing (1 viewing)
TOPIC: Re:Checkbox for duplicate Sitemap Datasource is missing
#5758
Ssoft-Solutions, Sven Scheidler
Checkbox for duplicate Sitemap Datasource is missing Karma: 0
i can't copy a datasource, because the checkbox is missing in list (row)?
Is this implemented?
Regards, Sven
#5760
Re:Checkbox for duplicate Sitemap Datasource is missing Karma: 84
duplicated here:
http://storejextensions.org/forum/view/10-jsitemap/309-re-checkbox-problem.html
and here:
http://storejextensions.org/forum/view/10-jsitemap/1836-re-sitemap-data-sources-can-t-be-selected.html
The 'content' data source can be copied if needed, activating 'Enable multiple 'Content' data sources' in the component configuration so it becomes selectable. Menu are automatically synced with only 1 instance.
Regards, John
