[SOLVED]jsitemap installation ( SQL error near '= 1, = 0... ) (1 viewing)
TOPIC: [SOLVED]jsitemap installation ( SQL error near '= 1, = 0... )
#1568
Pete
[SOLVED]jsitemap installation ( SQL error near '= 1, = 0... ) Karma: 0
Hi, my first post !!
I have just uploaded jsitemap 3.0.1 zip file and installed it through the extension manager.
I get an SQL error when installing and none of the admin pages work
1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '= 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'' at line 1 SQL=UPDATE dog_extensions SET = 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'
I then reinstalled the previous version and now all is working - but
The System Control Panel under JSITEMAP says Up-to-date Latest Release 3.0.1
The JSitemap PRO Control Panel says Outdated: Latest Release 3.0.1
Assuming I made an error in the method of updating. How do I correct the error in versions display and how should I do the update to 3.0.1?
Any assistance appreciated.
#1569
Re:jsitemap 3.0.1 update Karma: 84
Hi Pete!
The SQL error means that you are installing the wrong package on your Joomla version (installing package for Joomla 2.5 on a Joomla 3 installation)
Check the package name jsitemap_pro_v3.8_forjoomla3.x.zip -> for Joomla 3.x series
and jsitemap_pro_v3.8_forjoomla1.6_1.7_2.5.zip -> for Joomla 2.5
Best!
#1572
Pete
Re:jsitemap 3.0.1 update Karma: 0
Many thanks. My mistake, putting on the Dunce hat and standing in corner !
