Re:SQL for adding fields to custom URLs (1 viewing)
TOPIC: Re:SQL for adding fields to custom URLs
#3322
Glenn Harper
Re:SQL for adding fields to custom URLs Karma: 0
You are quite perceptive. Now the only thing missing is the locality is blank any thoughts about why?
#3323
Re:SQL for adding fields to custom URLs Karma: 84
Perfect, if the locality is blank it sounds like EZ Realty uses another field to store address informations. You should have a look at the EZ Realty table using phpMyAdmin to find fields and values... it's the correct way to proceed when analyzing a component.
#3324
Glenn Harper
Very good sir - thank you very much for your help!
#3325
