Re:I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left (1 viewing)
TOPIC: Re:I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left
#2723
Re:I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left Karma: 84
Hi all,
in the picture attached the website is not rendered with the Responsivizer template but exactly with the same Artisteer template used on desktop. Indeed when visiting your site Responsivizer is not active.
When you have activated Responsivizer then you can test it on Google and manage both menu modules to be rendered as mobile friendly. You can assign for example the horizontal menu to the position responsivizer_menu_top and the vertical to the position responsivizer_mainmenu
Another issue that i've noticed is that you have tables with fixed width '775px' that must be fixed to be fluid on mobile to avoid cutoff.
