Re:JRealtime Analytics from Components waits forever and does not open (1 viewing)
TOPIC: Re:JRealtime Analytics from Components waits forever and does not open
#6826
Re:JRealtime Analytics from Components waits forever and does not open Karma: 84
in the control panel is done the version check control to the remote server to find updates, so i guess that you have an issue on you server/PHP settings about opening a connection.
You could double check if functions such as fopen, fsockopen, curl, etc are enabled and if your hosting provider does not prevent remote connections using firewalls, etc
Best regards,
