Re:Screen Reader audio not play (1 viewing)
TOPIC: Re:Screen Reader audio not play
#3471
Re:Screen Reader audio not play Karma: 84
Hello again,
i read carefully your message from the JMS developers but it seems very weird that the initialization makes any difference... however we can do a test. I can change the initialization in the proxy.php as suggested in the Joomla 2.5 version and you can test if this makes any difference for JMS Multisite solving the problem.
Contact me by email at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it i can't send you files here.
#3474
Re:Screen Reader audio not play Karma: 0
Hello John
Changes in proxy.php work perfectly. Thank you for all the attention and excellent support.
#3475
Thank you Jose, case solved
