jsitemap pro + images (2 viewing)
TOPIC: jsitemap pro + images
#1153
francy
jsitemap pro + images Karma: 0
hi, i have joomla 2.5 + jsitemap pro and when i click on http://www.motustriathlon.com/index.php?option=com_jmap&view=sitemap&format=images&lang=en , give me internal server error. can you help me?
#1154
Re:jsitemap pro + images Karma: 84
this is quite common on large website and well documented at this FAQ: http://storejextensions.org/faq/why-when-i-try-to-generate-images-sitemap-i-get-a-server-error.html
If you can't increase server limits or if you don't want reduce the number of links processed the best solution is using the new feature of AJAX generation of the sitemap.
Everything is well explained in the pdf documentation.
kindest regards
#1163
francy
Re:jsitemap pro + images Karma: 0
i tried with ajax button but it's the same. do you have other solution?
thanks
#1164
#2077
Associazione WWOOF Italia
I've also tried to follow these instructions:
It still gives Error 500.
What can I do?
#2078
if you have already tried to reduce the parameter value for 'Images sitemap request limit' for example to 10, and you still get a server error the problem could be not due to a timeout.
In this case enabling the PHP debug option in jsitemap config and error reporting in the Joomla global config should report the exact problem on the page.
You have my direct email contact if on site help is required.
