missing xml code in images map warning in wmt (1 viewing)
TOPIC: missing xml code in images map warning in wmt
#1207
totoweb
missing xml code in images map warning in wmt Karma: 0
Checking in webmastertools I saw that the images map now detects a error. It says that it is missing an xml code?
See screenshot.
Raoul
#1208
Re:missing xml code in images map warning in wmt Karma: 84
hi Raoul,
if you refer to this sitemap: http://www.hollandhardware.com/en/?option=com_jmap&view=sitemap&format=images&lang=en
i just checked now if it was ok... the warning in webmasterstools could be related to the tag not found for example if the last fetch was not successful, try to resubmit it.
If you refer to another sitemap post here details.
#1210
totoweb
Re:missing xml code in images map warning in wmt Karma: 0
Hello John,
No it was http://www.coldmax.eu/index.php?option=com_jmap&view=sitemap&format=images&lang=nl
I just fetched it and resend it to the index. Let's see if that fixes the problem.
regards,
Raoul
