[SOLVED]Specify sitemap priority for only a few menu links (2 viewing)
TOPIC: [SOLVED]Specify sitemap priority for only a few menu links
#1266
Alexandre Thrrien
[SOLVED]Specify sitemap priority for only a few menu links Karma: 0
I got these menu in my data source that contains different items of different importance (or priority - 50%, 60%, 80%, 100%, etc).
It seems that the priority is set the same for an entire source in Jsitemap.
So my question is:
If I have a scenario where one menu link within a complete set of menu links from one menu data source is more important, would I need to exclude this element that I want to change the priority from the set of menu links, then create a NEW data source with only including this desired menu link ?
Thank you,
