Problems with Links to Kunena Threads in Sitemap (1 viewing)
TOPIC: Problems with Links to Kunena Threads in Sitemap
#1290
Ulrik Andresen
Problems with Links to Kunena Threads in Sitemap Karma: 0
I have added Kunena threads as a new data source. The resulting sitemap lists all threads correctly, but the links are not working.
I get a link like this: http://gichtinfo.de/index.php/component/kunena/2-gicht-allgemein/2-erster-beitrag
It results in an error 404 component not found.
The website is http://gichtinfo.de/
Link to sitemap: http://gichtinfo.de/index.php?option=com_jmap&view=sitemap
Joomla 3.3
Hope you can help,
Ulrik Andresen
#1291
Re:Problems with Links to Kunena Threads in Sitemap Karma: 84
Hello Ulrik,
it's normal because after adding the new data source for Kunena topics you have to enable the SEF auto-mode to replace partial sef links containing 'component/kunena' with full SEF links that will work normally.
Below a screenshot for the SEF mode setting.
#1292
Ulrik Andresen
Re:Problems with Links to Kunena Threads in Sitemap Karma: 0
Hello John,
thank you for the quick answer. But I can´t find the option to turn on the alias for SEF links. Do I need the pro version to do this?
Ulrik Andresen
#1293
