Re:tips for beginners (1 viewing)
TOPIC: Re:tips for beginners
#1369
gaetano
Re:tips for beginners Karma: 0
ok i understan but I'm a little confused.
i want index alone this: /media/reviews/photos
i don't want index it: /images
is correct the setting in the pictcure
#1370
Re:tips for beginners Karma: 84
it's not required add the full path to the include/exclude filters, it's enough set only a subpath
In your case:
- Include filters add only 'reviews'
- Exclude filters remove 'media'
As shown in the attached picture, only images such as '/media/reviews/photos' including 'reviews' in the path will be indexed
#1371
gaetano
ok thank you
curiosity, but you speak italian ?
#1372
gaetano
why i see always a hold images sitemap, how can regenerate a new iamges map ?
#1373
If you mean an 'old' images sitemap, check that there are no caching systems active.
If you are using ajax generation start a new process to refresh the sitemap.
#1374
gaetano
excuse me for my request
now jreview image are index,
but i see that even images of menu are index. how can exclude it ?
