Re:Is it possible to create a Video Sitemap for Google with JSitemap Pro ? (1 viewing)
TOPIC: Re:Is it possible to create a Video Sitemap for Google with JSitemap Pro ?
#1518
Derek Moran
Is it possible to create a Video Sitemap for Google with JSitemap Pro ? Karma: 0
Hi there
Firstly I would like to thank you for one of the best Joomla Extensions on Earth. Before JSitemap Pro it was a nightmare to keep my sitemap up to date and accurate. JSP removed all my stress.
I would like to know if it is possible to create a Video Sitemap using JSitemap Pro ?
Google Webmasters has a few articles on this topic here:
https://support.google.com/webmasters/answer/156442?hl=en&topic=2370565&ctx=topic
https://support.google.com/webmasters/answer/80472
Most of my website contains embedded video and I would like to get Google to show thumbnails for these videos in the search results. I realize that I also have to add Mark Up to all my Videos with Schema.org for this to happen. Creating a Video Sitemap is part of the puzzle.
I'm also wondering if there might be an alternative solution and I can simply add extra "video mark up fields" to my existing sitemap ? I know I have a lot more research to complete on this topic, but I thought asking here would be a good starting point.
Derek
#1521
Re:Is it possible to create a Video Sitemap for Google with JSitemap Pro ? Karma: 84
Hello Derek and thank you very much
We thought a lot about creating video sitemaps, but unfortunately it seems not reliable trying to generate them automatically mainly because videos need a lot of meta informations for the sitemap that are in most cases not available in the HTML.
Probably in some next version of JSitemap we'll try to develop a system to generate a video sitemap using a record l ist in backend to manage video links and meta tags, this seems a bit better solution.
