Re:Where does it read from? Category or menu (1 viewing)
TOPIC: Re:Where does it read from? Category or menu
#1544
Smel
Where does it read from? Category or menu Karma: 0
Wamp server, localhost, Joomla 2.5.28, Jsitemap PRO 3.0
SEF ON,
SEF rewrite OFF in configuration.php
Main menu unpublished,
Content published in JMAP Sitemap Data Sources settings
Category structure
A
|—B
|—C
Menu items structure
C
|—B
|—A
JMAP outputs XML items as if it extracts from menu items. For example, http://localhost/index.php/c/b/1.html
#1545
Re:Where does it read from? Category or menu Karma: 84
data sources for menu and content are independant.
The data source 'content' generates the structure of the sitemap based on the tree of categories in Joomla.
The menu data source instead generates the menu tree.
#1546
Smel
Re:Where does it read from? Category or menu Karma: 0
Content which is published must generate the output like http://localhost/index.php/a/b/1.html
However the output is like http://localhost/index.php/c/b/1.html and it is the structure of menu tree.
Does it say that Jsitemap won't check the data source if it is published/unpublished?
#1547
Yes of course.
This is how the native Joomla routing works, when menu are directly pointing to categories the menu alias is used to build urls.
The sitemap uses the same SEF system of the site and output same links.
If you want an URL structure not based on menu but on contents you need third party solution such as sh404sef.
