[SOLVED]Problem with site-map configuration (1 viewing)
TOPIC: [SOLVED]Problem with site-map configuration
#1582
Andrew Sampson
[SOLVED]Problem with site-map configuration Karma: 0
I just upgraded my version of JSitemap and there is an issue with trying to make changes in the Configuration.
Every time I go into the config area I get this box coming up asking to upload an image.
I have no idea why!
(see enclosed image)
Our site is a very large one with thousands of articles on it
best
Andrew
#1583
Re:Problem with site-map configuration Karma: 84
Hi Andrew,
that's really incredible, it looks like a sort of javascript conflict with some other plugins installed. The upload box normally opens only when you click on the button to upload an image for the feed.
Best
#1584
Andrew Sampson
Re:Problem with site-map configuration Karma: 0
Yep!
Pretty weird!
Have sent you log in details!
The site is stuffed to the gills - be warned.
Andrew
#1585
Yep! Never seen before!
however i will have a look
#1919
1-2-appletree
Hello John,
I just installed JSitemap PRO 3.3 and looking around all new features and got exact the same problem. Button 'Control Panel' does not wordk anymore, it still asks for uploading an image. And I did uploading an image, but then it asks again...
Kind of a bug?
If you need access, please let me know.
Nico
#1921
Hello Nico,
contact me directly by email for this... no other cases of this issue are known, looks more are something weird going on server.
