Re:SQL Error updating from 3.0.1 to 3.1 (1 viewing)
TOPIC: Re:SQL Error updating from 3.0.1 to 3.1
#1605
Michael Holl
SQL Error updating from 3.0.1 to 3.1 Karma: 0
trying to update from Version 3.0.1 to 3.1 on a Joomla 3.3.6 Site causes the following error message.
Needless to say the component is totally broken afterwards.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '= 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'' at line 1 SQL=UPDATE fd_extensions SET = 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'
Please fix ASAP,
Thank you.
#1607
Re:SQL Error updating from 3.0.1 to 3.1 Karma: 84
Hello Michael,
you are installing the wrong package, please see this forum thread already discussed: http://storejextensions.org/forum/view/10-jsitemap/1568-solved-jsitemap-installation-sql-error-near-1,-0.html
