[SOLVED] Help with Jomres (1 viewing)
TOPIC: [SOLVED] Help with Jomres
#1637
Hrvoje Znaor
[SOLVED] Help with Jomres Karma: 1
Can you help me with creating custom data source for Jomres?
I see that all accommodation units are listed in sitemap, but I cannot get generated URL's to open property details.
UPDATE:
(solved by John's help)
A solution, just in case that someone else might need it:
- Click new Data Source, and name it Jomres
- Enter additional params for query string: task=viewproperty
- Manual menu item alias for SEF links: Select your Jomres menu item
- Select from this table: jomres_propertys
- Select this field as TITLE used for link text: property_name
- Select this field as ID needed for link: propertys_uid AS property_uid
- Where condition #1: published = 1
- Where condition #2: approved = 1
Check your Jomres related sitemap links.
Joomla 3.3.6
Jsitemap pro 3.1
#1638
Re:Help with Jomres Karma: 84
yes i can help you to setup the data source, i need an admin account.
#1639
Hrvoje Znaor
Re:Help with Jomres Karma: 1
Hi John
Details sent. Pls check your spam folder, just in case
#1640
Done
Just answered you
#1641
Hrvoje Znaor
Thanks for very quick response, especially during Sunday
You are providing excellent support!
Best Regards
#1642
Thank very much i do my best
Hope is appreciated
