Google analytics integration problem (1 viewing)
TOPIC: Google analytics integration problem
#1666
Roger
Google analytics integration problem Karma: 0
I have been using Google analytics for some time. Now I'm trying to use the integration into jsitemap pro 3.1, without success unfortunately.
Having consulted the documentation didn't help.
I push the button "Get Google access code" I the get the same as shown in the doc. "Show Google analytics data" Accept
What follows is an Error 400 malformed request.
Can you please advice? I'm using Akeeba Admin Tool, could this be a problem?
Roger
#1667
Re:Google analytics integration problem Karma: 84
Hello again Roger,
yes normally it's a matter of copy and paste the Google code.
It could be a security issue of Admin Tool, if the url is changed Google could receive the wrong URL and show that error.
Try to disable temporary Admin Tool and check if something changes.
Eventually try also to login to your Google Analytics account just to ensure that it's still active and working.
