How not to load Bootstrap (1 viewing)
TOPIC: How not to load Bootstrap
#1749
Law Promo
How not to load Bootstrap Karma: 0
my template isn't using bootstrap, but jsitemap is loading it. Is there way to prevent it from loading bootstrap to the front end? thanks.
#1750
Re:How not to load Bootstrap Karma: 84
Hi all,
no jsitemap loads only jquery but not bootstrap on the frontend. The sitemap is rendered without bootstrap it's needed and loaded only in the backend.
maybe there is some other extensions/modules loading it, especially if you are using Joomla 3 bootstrap is usually loaded by default
john
#1751
Law Promo
Re:How not to load Bootstrap Karma: 0
Well, it wasn't loading until I installed the jsitemap today. Now it's loading and I can't even do a template override - it won't work...
#1752
