J!Extensions Store™
Re:Multilanguage site and Sitemap link (1 viewing)
TOPIC: Re:Multilanguage site and Sitemap link
#1797
Alexandre Thrrien
[SOLVED]Multilanguage site and Sitemap link Karma: 0
Hello, I translated my site with a fairly simple joomla component called JA Multilanguage that adds language strings to the url:
Primary Language: http://www.mauzaza.com/en
Secondary Lanague: http://www.mauzaza.com/id
Looking at the sitemap link structure generated by jsitemap I realise that this might be a problem impeding the site to be crawled properly.
Explanation:
If you submit this link: http://www.mauzaza.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=en
it is redirected to this link: http://www.mauzaza.com/en/index.php?option=com_jmap&view=sitemap&format=xml&lang=en
Same thing for the secondary language.
Any thoughts?
#1798
Re:Multilanguage site and Sitemap link Karma: 79
Hello Alex,
this is known and it happens because the Joomla multilanguage plugin does the redirect when you open that link in the browser.
However JSitemap already has the technology to avoid 301/303 redirects when a bot lke Google bot or Bing are coming to crawl the sitemap, they always get the real direct link.
#1819
Alexandre Thrrien
Re:Multilanguage site and Sitemap link Karma: 0
#1820
Hello Alex,
yes exactly, you need to submit 2 sitemaps, one per each language using the links above.
http://www.mauzaza.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=en http://www.mauzaza.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=id
have a nice day
#1821
Alexandre Thrrien
Alright John, thanks a lot. have a nice day too
#1824
Alexandre Thrrien
Hi John, what's the easiest way to exclude a link when GWT reports an error?
He didn't like the Gravatar links..
Errors
Invalid URL
This is not a valid URL. Please correct it and resubmit.
4
URL: //www.gravatar.com/avatar/d5354cf4d005c175ecc3c486e1730788?s=60&default=http%3A%2F%2Fwww.mauzaza.com%2Fcomponents%2Fcom_k2%2Fimages%2Fplaceholder%2Fuser.png
Parent tag: image
Tag: loc
8364
Mar 26, 2015
URL: //www.gravatar.com/avatar/543c8ced2f2a38277a0fba3d2210c58a?s=60&default=http%3A%2F%2Fwww.mauzaza.com%2Fcomponents%2Fcom_k2%2Fimages%2Fplaceholder%2Fuser.png
Parent tag: image
Tag: loc
8774
Mar 26, 2015
Parent tag: image
Tag: loc
8981
Mar 26, 2015
Thank you
