Rich Snippets and google and jsitemap (1 viewing)
TOPIC: Rich Snippets and google and jsitemap
#1920
KUBEVENT
Rich Snippets and google and jsitemap Karma: 0
hi
In google webmaster tools you could use a script to see if there is schema.org datasource etc you know ?
is there any things related about this in Jsitemap ?
for example for K2 it seems it didnt recognize title description etc ..
https://www.kubevent.fr/fr/prestations-kubevent/spectacles-festivals/election-miss-prestige-2013-au-lido
how or witch extension to progress on rich snippets for SEO ?
#1922
Re:Rich Snippets and google and jsitemap Karma: 84
hi again,
the rich snippet management based on schema.org is a missing feature of Joomla. There was a proposal and a development going on this, but it's still not integrated in Joomla.
Title and descriptions however are not rich snippets, they are normal meta info.
An extension plugin to manage schema.org rich snippet is this: http://extensions.joomla.org/profile/extension/site-management/seo-a-metadata/j4schema
#1923
KUBEVENT
Re:Rich Snippets and google and jsitemap Karma: 0
Hi john thanks i have seen this but i am not sure i really need this in order not to conflict for all we use for the moment and i am not sure about the good effect on code for SEO
is it really a feature to have ? in order have a good referencement on google ?
#1924
Well, rich snippets are not mandatory. I was hoping that Joomla will integrate them in version 3.5.
By the way the j4schema plugin should not conflict with other extensions.
The most important thing however, is ensure to set properly titles and descriptions for your contents, this is the main contents used by Google.
