Re:XML processing fault (1 viewing)
TOPIC: Re:XML processing fault
#1979
Re:XML processing fault Karma: 84
Hello Klaus, the principle is still the same. You can identify the folder in which the blocked resources are located and remove the disallow from the robots. Probably they are resources from components or modules. As soon as they are not effective for the mobile you can also leave them as inaccessible to google.
john
Boomgaarden Klaus
thread linkthread link Re:XML processing fault
Boomgaarden Klaus
thread linkthread linkthread link Re:XML processing fault
Boomgaarden Klaus
thread linkthread linkthread linkthread link Re:XML processing fault
Paul Hayward
thread linkthread linkthread linkthread linkthread link Re:XML processing fault
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread link Re:XML processing fault
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread linkthread link Re:XML processing fault
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Google Webmaster Tools / XML = Wrong file?
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools / XML = Wrong file?
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools / XML = Wrong file?
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools / XML = Wrong file?
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools
Boomgaarden Klaus
thread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread linkthread link Re:Google Webmaster Tools
