Problems with jsitemap module & dataset (1 viewing)
TOPIC: Problems with jsitemap module & dataset
#2041
Jean
Problems with jsitemap module & dataset Karma: 0
I'm having trouble with the jsitemap module, as seen in the pic below;
Also not able to save or add any details into the dataset - it's blank.
I'm wondering if it's to do with upgrading it, as I recently upgraded from an older version of jsitemap to the latest 3.3pro version. Initially I had problems with saving the config, but sorted that out with deleting the browser cache.
cheers,
Jeannie
#2042
Re:Problems with jsitemap module & dataset Karma: 84
Hello Jeannie,
about the screenshot 2, the problem could have been related to the cache after an upgrade to the latest release. Clearing cache should solve. About the screenshot 1, the problem should be related to the plugin 'JSitemap Utilities' that normaly should be published. Eventually check if that plugin is published.
Thanks,
