Re:Easyblog dataset trouble setting (1 viewing)
TOPIC: Re:Easyblog dataset trouble setting
#2060
lematmat
Easyblog dataset trouble setting Karma: 1
I'm using Easyblog on my website and I've managed to display all the blog posts on the HTML sitemap .
But when I set the parameters of Easyblog datasource like :
Title for data source = Blog
then the blogposts disappear even after emptying Joomla cache.
Could you help to fix that ?
lematmat
Sitemap URL: http://www.ava-lawfirm.eu/plan-du-site
Joomla: 3.4.1
JSitemap: 3.3
I'm using sh404
#2061
Re:Easyblog dataset trouble setting Karma: 84
the problem could be related to an old PHP directive 'magic quotes' if still active on the server. Eventually try to check in the Joomla system informations if this is the case as shown in the picture below. Magic quotes must be 'off'.
best regards
#2062
lematmat
Re:Easyblog dataset trouble setting Karma: 1
I confirm that Magic quotes is off.
lematmat
