Re:JSitemap Backend Admin Menu (1 viewing)
TOPIC: Re:JSitemap Backend Admin Menu
#2229
AxaCloud
JSitemap Backend Admin Menu Karma: 0
Is there a way to disable the JSitemap icons that are displayed in the various backend admin menus. Like the one in the component drop-down menu?
Thanks!
Sima
#2233
Re:JSitemap Backend Admin Menu Karma: 84
Hello SIma,
if you mean the icon showed before of the name under the component menu, yes the icon is placed in the translations file of the backend component, you can remove it from that file.
#2235
AxaCloud
Re:JSitemap Backend Admin Menu Karma: 0
Yes that is what I meant. Thanks for your quick reply!
