Re:Docman document not appearing site map after update (1 viewing)
TOPIC: Re:Docman document not appearing site map after update
#2245
Franck Tanoh
Docman document not appearing site map after update Karma: 0
I have lost all my docman documents from my site map and rss feed since I updated my site to docman 2.12 (from docman 2.0). After some investigations, i have noticed that the auto-generated SQL below has the following line:
AND (`#__docman_documents`.`access` IN {aid} OR `#__docman_documents`.`access` = -1)
When i replace {aid} by '0' and run the query in phpadmin, i get a result. I tried without success to remove {aid} from the auto-generated SQL. What is the {aid} for? Can this be the problem or do you have some advice for me to get my document back? Auto-generated sql
SELECT `#__docman_documents`.`title`, CONCAT_WS('-',`#__docman_documents`.`docman_document_id`,`#__docman_documents`.`slug`) AS `alias`, `#__docman_categories`.`title` AS `cattitle`, `#__docman_categories`.`slug` AS `category_slug` FROM `#__docman_documents` JOIN `#__docman_categories` ON `#__docman_documents`.`docman_category_id` = `#__docman_categories`.`docman_category_id` JOIN `#__docman_category_relations` ON `#__docman_categories`.`docman_category_id` = `#__docman_category_relations`.`descendant_id` WHERE `#__docman_categories`.`enabled` = '1' AND `#__docman_category_relations`.`ancestor_id` = '1' AND (`#__docman_documents`.`access` IN {aid} OR `#__docman_documents`.`access` = -1) ORDER BY `#__docman_categories`.`created_on` ASC, `#__docman_documents`.`title` ASC
#2246
Re:Docman document not appearing site map after update Karma: 84
#2247
Franck Tanoh
Re:Docman document not appearing site map after update Karma: 0
Thanks for your reply.
How do i remove the {aid}? It seems to automatically appear in the query.
Franck
#2248
Hi Franck,
you can simply edit the SQL string for example, copy and paste the below string and click the 'Save and close' button in the data source:
SELECT `#__docman_documents`.`title`, CONCAT_WS('-',`#__docman_documents`.`docman_document_id`,`#__docman_documents`.`slug`) AS `alias`, `#__docman_categories`.`title` AS `cattitle`, `#__docman_categories`.`slug` AS `category_slug` FROM `#__docman_documents` JOIN `#__docman_categories` ON `#__docman_documents`.`docman_category_id` = `#__docman_categories`.`docman_category_id` JOIN `#__docman_category_relations` ON `#__docman_categories`.`docman_category_id` = `#__docman_category_relations`.`descendant_id` WHERE `#__docman_categories`.`enabled` = '1' AND `#__docman_category_relations`.`ancestor_id` = '1' ORDER BY `#__docman_categories`.`created_on` ASC, `#__docman_documents`.`title` ASC
After that check if documents are included in the sitemap John
#2249
Franck Tanoh
My mistake, i kept clicking on the 'regenerate SQL query' instead of the save button.
Anyway, it works fine now after i removed it and i have my document back.
It looks like in docman 2.12, document security is now based on User group instead of Access Level. So this might be the problem.
Many thanks for your help.
Franck
#2250
