problem installing the extension (1 viewing)
TOPIC: problem installing the extension
#2279
Alejandro Abuamer Flores
problem installing the extension Karma: 0
each time I install jsitemap google chrome crashed... and it resets... after this all works ok...
this is the error report
Process: Google Chrome [11227]
Path: /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
Identifier: com.google.Chrome
Version: 42.0.2311.135 (2311.135)
Code Type: X86-64 (Native)
Parent Process: launchd [342]
Responsible: Google Chrome [11227]
User ID: 501
Date/Time: 2015-05-06 12:39:29.990 +0200
OS Version: Mac OS X 10.9.5 (13F34)
Report Version: 11
#2280
Re:problem installing the extension Karma: 84
there is no relations between a Joomla component installation and the browser... check if the problem could be a timeout of the browser and use Safari if you are on a Mac.
#2282
Re:problem installing the extension Karma: 0
the first time I see this when I install any extension
#2283
me too, i've never heard about this
#2285
but the both times I installed your extension it happened to me...
#2286
Please run some tests installing on another browser and installing other extensions with the same size in MB, this helps to understand something more.
