Re:Virtuemart 2 (1 viewing)
TOPIC: Re:Virtuemart 2
#2330
Alejandro Abuamer Flores
Virtuemart 2 Karma: 0
I only see this extension analyzes joomla content. I need it analyzes virtuemart products too. How could I do this?
thx
#2332
Re:Virtuemart 2 Karma: 84
Hello Alejandro,
it makes no difference between components that are included in the sitemap. If you mean the links analyzer it also analyzes virtuemart products once added to the sitemap.
#2333
Re:Virtuemart 2 Karma: 0
ok, thx
and I have to do anything special if I have a multi-language site or all is automatic?
#2334
if the site is multilanguage normally you only submit a sitemap for each language installed and nothing more. Every updates will be automatic.
#2337
and how can I do this?
#2338
When your site is multilanguage in the SEO dashboard a dropdown for each language is showed. Selecting different languages the sitemap links are updated and formatted accordingly and they are ready to be submitted.
For example:
http://www.mysite.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=en http://www.mysite.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=es http://www.mysite.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=fr
...etc...
Detailed info about multilanguage sitemaps are included in the pdf documentation.
