Re:Virtuemart 2 (1 viewing)
TOPIC: Re:Virtuemart 2
#2343
Alejandro Abuamer Flores
Re:Virtuemart 2 Karma: 0
ok, thx
with this is enough?
#2344
Re:Virtuemart 2 Karma: 84
Yes exactly, for each format that you submit specify different languages, for example 2 for XML and 2 for images:
index.php?option=com_jmap&view=sitemap&format=xml&lang=en
index.php?option=com_jmap&view=sitemap&format=xml&lang=es
index.php?option=com_jmap&view=sitemap&format=images&lang=en
index.php?option=com_jmap&view=sitemap&format=images&lang=es
You submit all required sitemaps in this way.
#2345
I suposed I have VM categories and product into xml site:
but in google webmaster I only see 29 web pages (with products should be much more web pages)
thx
#2346
If you added at a later time Vm products and categories check if the sitemap is not cached.
Also if you already submitted the sitemap previosly, GWT could have cached it. To force a new fetch of GWT a new link for the sitemap can be used enabling the parameter for random links generation
#2347
but can I let it and tomorrow, automatically, GWT will update it?
PS Submit Sitemap to GWT button doesn't work
