Uncaught exception 'RuntimeException' with message 'Unable to load renderer class' (1 viewing)
TOPIC: Uncaught exception 'RuntimeException' with message 'Unable to load renderer class'
#2375
Ozjokes
Uncaught exception 'RuntimeException' with message 'Unable to load renderer class' Karma: 0
Hi
I just installed JSitemap Pro and this is the message on the XML sitemap. Is there something else i'm supposed to have?
Joomla 3.0
http://www.ozjokes.com/component/jmap/sitemap/xml?format=xml
#2376
Re:Uncaught exception 'RuntimeException' with message 'Unable to load renderer class' Karma: 84
it seems an error due to the routing of Joomla XML formats and the Gantry template installed.
Use the normal link for the XML sitemap instead of the rewritten one that you posted, it works better in most cases and just tested on your site:
http://www.ozjokes.com/index.php?option=com_jmap&view=sitemap&format=xml
Greetings, John
#2377
Ozjokes
Re:Uncaught exception 'RuntimeException' with message 'Unable to load renderer class' Karma: 0
Perfect thank you.
