Re:JFB Connect (1 viewing)
TOPIC: Re:JFB Connect
#2443
William Brannan
[SOLVED]JFB Connect Karma: 0
I installed jsitemap pro and discovered that all of the social sharing buttons from jfb connect disappeared.
#2444
Re:JFB Connect Karma: 84
Hi William,
there are no know issues, conflicts, etc between jsitemap and jfbconnect.
Also jsitemap is a component executed only on demand in frontend, not on all pages.
however to check if buttons are disappeared for some reason related to jsitemap, disable all jsitemap extension in the extensions manager of Joomla and check if social sharing buttons come back.
#2445
William Brannan
Re:JFB Connect Karma: 0
Thanks John,
I think I know what the problem was. I restored the site from yesterday's backup, made all of the changes and all is working well. Thanks.
