sitemap not generated (1 viewing)
TOPIC: sitemap not generated
#250
perso
sitemap not generated Karma: 0
hi i'll just purchase jsitemap, he work well on my xampp lab
But on live site he don't generate the sitemap, (page blank)
need help its urgent, thanks a lot
#251
Re:sitemap not generated Karma: 84
Hello and thanks to contact us,,
if you experiment issue about memory probably it's due to amount of records
to process on your live site and the memory limit set on server.
You should limit records processed or set a higher limit for memory on php.ini.
If you would like send us an admin account to have a look to number of records
and sitemap setup.
Thank you and best regards
