Re:Upgrade to 3.3.1 breaks my site (1 viewing)
TOPIC: Re:Upgrade to 3.3.1 breaks my site
#2504
Surrey Community Music Society
Upgrade to 3.3.1 breaks my site Karma: 0
Upgrading to 3.3.1 causes errror during installation and completely breaks site including fronted, error displayed is:
Warning -
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '= 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'' at line 1 SQL=UPDATE cbc_extensions SET = 1, = 0 WHERE type = 'plugin' AND element = 'jmap' AND folder = 'system'
Current config: Joomla 3.4.1 stable, JSitemap Pro 3.3, PHP 5.6.9
#2505
Re:Upgrade to 3.3.1 breaks my site Karma: 0
Sorry, I just realised I downloaded the wrong version for Joomla 2.5! Aaarghhhh.... my apology!
Cliff
#2506
Re:Upgrade to 3.3.1 breaks my site Karma: 84
Hi Cliff,
yes that is the problem, already discussed and solved here: http://storejextensions.org/forum/view/10-jsitemap/1568-solved-jsitemap-installation-sql-error-near-1,-0.html
