Re:SobiPro (1 viewing)
TOPIC: Re:SobiPro
#2547
Matthias Schneider
[SOLVED]SobiPro Karma: 0
Hello, I integrated SobiPro into JSitemap. It works! However, I have several sobiPro directories -for example: shops, restaurants, museums and I would like a separate JSitemap object (entry) for each SobiPro directory. Is it possible to realize this? What I have to do?
Thx for your answers !
#2549
Re:SobiPro Karma: 84
Hello Matthias,
it would be possible having multiple data sources for Sobipro and then filtering each data source for example by section ID or category IDs.
I don't know if you are using the wizard SQL based data source or the installable plugin data source, In the latter case the plugin has a filter for sections.
#2551
Matthias Schneider
Re:SobiPro Karma: 0
Hello John,
it works ... perfect!
Thanks a lot !
Matthias
