Re:If I purchase JSitemap do I need other SEO tools like EFSEO? (1 viewing)
TOPIC: Re:If I purchase JSitemap do I need other SEO tools like EFSEO?
#2583
All American Van Lines
If I purchase JSitemap do I need other SEO tools like EFSEO? Karma: 0
I have purchased some other extensions here such as Responsivizer and JAnalytics. I am now considering purchasing JSitemap.
Is JSitemap different to SEO plugins such as Easy Front End SEO and SEO Generator? Would I need to purchase Jsitemap along with an SEO plugin?
Thanks!
#2584
Re:If I purchase JSitemap do I need other SEO tools like EFSEO? Karma: 84
Hi thanks for interest,
i don't know exactly all the features included in the other extensions, however probably many features are already included in JSitemap, such as the meta tags management. If the SEO plugin that you are using doesn't deal with sitemaps however you need JSitemap for your website.
thanks!
#2586
Re:If I purchase JSitemap do I need other SEO tools like EFSEO? Karma: 0
Thanks for your response. Does JSitemap handle metatags automatically? Or do I have to do that manually for each article?
#2587
Yes you can handle metatags for each specific links of the website/sitemap, thus you can manage all extensions.
But this works as an override, if you don't add specific metatags the default ones generated by Joomla will be used.
Keep in mind that there is not a magic solution to do this automatically, metatags must be added in a correct way to be effective for SEO.
