Re:JSitemap Cache issue (1 viewing)
TOPIC: Re:JSitemap Cache issue
#2718
mediaDESIGN St. Kraft
[SOLVED]JSitemap Cache issue Karma: 0
I use JSitemap in a project with thousands Virtuemart categories and products.
In documentation I have read, that ich can activate the precaching feature for faster execution, but I think it do not work. In SEO dashboard I start precache process and after that i call the xml sitemap or html sitemap. But the receiving needs up to 3 minutes. Then i can see in SEO dashboard, that the status of xml sitemap was reseted to "no cached".
I need help to realy activate the cache feature.
#2720
Re:JSitemap Cache issue Karma: 84
the precaching is done for XML formats and not HTML. After the precaching has completed, the label must be 'green' and report 'cached' with a date. If it looks red 'no cached' it means that something is going wrong.
For a HTML sitemap usually it would be better limiting the number of products to the most recent or include links only to categories of products, A large HTML sitemap could slow down the browser for the user visiting the site.
if you need help to configure the precache on site, please contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it providing an admin account.
regards,
#2721
Re:JSitemap Cache issue Karma: 0
John, Thank you so much for fast and prompt support.
Now my multi-language-multi-domain project shows large sitemaps very fast. I'm so happy.
#3144
pistipixel
hi,
Its not possible to precache the sitemaps (only the normal xml).
After some minutes the popup close and nothing happens.
regards Jürgen
#3145
pistipixel
pistipixel wrote:
QUOTE:
hi,
regards Jürgen
#3146
are you referring to precache the images sitemap?
regards,
