Re:Jsite Map Not generating xml and HTML (1 viewing)
TOPIC: Re:Jsite Map Not generating xml and HTML
#2741
eLegal.org
Jsite Map Not generating xml and HTML Karma: 0
Sir,
we have installed jSitemap and after that in jsitemap control panel , we have add two new data source using "wizard data source" after that we clicked on "show SiteMap HTML"(www.elegal.org/index.php?option=com_jmap&view=sitemap) and for xml(http://www.elegal.org/index.php?option=com_jmap&view=sitemap&format=xml) but it's not generating.
we want all listing and category in xml and html site map.
lets know if any information or changes required from us.
Raviraj Kumar
#2742
Re:Jsite Map Not generating xml and HTML Karma: 84
Hello Raviraj,
the problem could be related to scalability. If you have added data sources including too many (thousands) of links in the sitemap the generation could take a lot of time and not complete.
For the HTML sitemap normally you should include max 5000-10000 links otherwise the browser hangs to render the sitemap tree to the end user.
For the XML sitemap you can use the precaching feature if for example the sitemap includes 100.000 links.
Contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it providing an admin account for on site help.
Best regards,
#2758
eLegal.org
Re:Jsite Map Not generating xml and HTML Karma: 0
Sir,
Whenever we want to make changes in the "Mosets tree categories" Data source like "Manual menu item alias for SEF links" - selecting an menu"directory" and after clicking on "save & close" button, we are getting following response
403: Access Forbidden
SQL injection attempted.
so, sir please suggest us what we need to do for resolving error and saving data source configuration successfully.
Raviraj Kumar
#2759
Dear Sir,
it looks like you have a plugin installed that prevents saving of SQL string used in the data source. Check if you have installed RS Firewall and if so add an exception for the sitemap component.
About the Mosets tree, if you have thousands of links the sitemap will results in too much time to complete, Mosets tree is a very resource intensive extension, thus follow my advice in the previous post using only categories for HTML sitemap and using precaching for XML.
