Rss feed is not in chronological order (1 viewing)
TOPIC: Rss feed is not in chronological order
#2889
Giovanni
Rss feed is not in chronological order Karma: 0
Hello ...
Surely I am doing something wrong but I can't have my rss feed in chronological order. If I take a look in my rss feed (default Joomla's K2 rss feed is not working anymore) I can see also latest news, but It's not from the latest to older in rss!
What shall I check in my configuration?
Thanks!
#2890
Re:Rss feed is not in chronological order Karma: 84
not sure to understand well your question... do you need to generate an RSS feed for K2 articles in a reverse chronological order?
If so the first parameter to change in the data source configuration of K2 articles is the one shown in the image below,
using 'created' as 'descendant'
Greetings!
#2891
Giovanni
Re:Rss feed is not in chronological order Karma: 0
Sorry ... It was my fault! I think I use just 1% of your component!
Yes, you are right! It was ordered by title, and I needed By publish date!
How Can I re-create rss feed, now that I have changed ordering option?
Thank you so much
#2892
Well at least i was right
Once changed the setting for ordering option it will take effect immediately in the RSS feed if generated in realtime as by default, unless a caching for the feed is activated,
#2893
Giovanni
John Dagelmore wrote:
QUOTE:
Well at least i was right :D
... and .... where do I have to activate that "real time" thing? Yeah I am misusing!
#2894
It's already active Nothing to activate... when you generate the rss feed it's done in realtime based on current settings.
