Checkbox problem (1 viewing)
TOPIC: Checkbox problem
#308
Partenaireweb
Checkbox problem Karma: 0
JSitemap Professional on joomla 3.2.2
I do not have a check box in the administration sitemap Data Sources.
see image attache .
Regards.
#309
Re:Checkbox problem Karma: 84
this is normal, the checkboxes are showed only for custom data sources of type 'user', 'plugin', 'links'.
The list of data sources of type 'menu' and 'content' are managed automatically by component and can't be deleted.
Optionally if 'Enable multiple 'Content' data sources' in the component configuration is set to 'Yes' the 'content' data source it becomes selectable to be duplicated.
