Re:JBusinessDirectory (1 viewing)
TOPIC: Re:JBusinessDirectory
#3166
Iordache Alexandru-Cristian PFA
JBusinessDirectory Karma: 0
I want to include in
QUOTE:
Sitemap Data Sources
a component i use - Jbusiness Directory ... can you please help me to do this?
Thank you very much.
#3167
Re:JBusinessDirectory Karma: 84
you find in the download area -> folder 'Data sources to import for third party extensions' 2 data sources already configured for JBusiness Directory. You can download and try it on your site.
The reason why it's not integrated in the wizard is because it's a component not following Joomla standards and generating URLs in a proprietary way using an internal router that often requires a custom hardcoded integration.
#3168
Re:JBusinessDirectory Karma: 0
Thank you.
#6288
john
Hi
Does the latest jsitemap version integrate JBusinessDirectory in the wizard? If not which features (categories...) include data sources provided by latest jsitemap version? Thanks.
#6289
JBusiness Directory is integrated with JSitemap by the official plugin data source developed by CMSJunkie several months ago. It requires JBusiness Directory 4.6 and later and includes categories, companies, etc
Once purchased a license you have access to download everything,
thanks.
#6301
john
Hi
Does JSitemap include JBD plugin + data source to import? Any demo available? Thanks
