J!Extensions Store™
Re:Errors in SEO stats (1 viewing)
TOPIC: Re:Errors in SEO stats
#3225
CW WebworX
Errors in SEO stats Karma: 1
We just starting getting errors in SEO stats windows. See attached image please. Not sure how to fix this.
Thanks.
#3226
Re:Errors in SEO stats Karma: 79
this means that you have recently installed an extension/plugin on Joomla that breaks the Joomla JSON/Javascript output. In this way the javascript communication with Joomla is broken and prevented.
Go through recent changes and installed plugins to discover which one is the cause.
Thanks.
#3227
CW WebworX
Re:Errors in SEO stats Karma: 1
Hi, The only change that was made was an update to JCE editor. It was working fine until this update.
Could that cause this?
Thanks.
#3228
I don't think... it seems more that the plugin causing the issue is related to routing or spam/security block. JCE is only an editor... a good approach would be having a test site to exclude plugins until it works again to find the one causing the issue.
#3229
CW WebworX
its happening now on multiple sites with Jsitemap pro. All i did recently was update JsitemapPro to latest version, updated JCE. I tested it on two sites now and both have this problem now, but didn't before. Could this be htaccess related? Although we haven't changed the htaccess either.
Thanks John
Cheers!
#3230
Yes the htaccess could be the problem!
Indeed i noticed that the javascript requests are redirected to the home page in frontend.
