Glenn Harper
[SOLVED]SQL for adding fields to custom URLs
I have EZ Realty and Jsitemap Pro and I can't seem to get the links to display more than one EZRealty field at a time.
I seem too remember seeing something involving CONCAT_WS or something but I don't find it in the user guide.
Can somebody point me to directions for building URLs that could have fields like price, address, description, etc. strung together to make the link?
Logged
Re:SQL for adding fields to custom URLs
Hello Glenn,
if you have configured a custom data source for EZ Realty and you want to concatenate SQL fields for the title you must use the CONCAT_WS in the raw SQL query.
For example if you have a query like this:
SELECT title FROM ....
you can concatenate fields like this:
SELECT CONCAT_WS(',','title','price','address' ) AS title FROM .....
Notice that this is used for the title not for the link and URL.
Logged
Glenn Harper
I've been trying several times to use your code, but I obviously don't know what I'm doing,
Here is what is regenerated:
SELECT
`#__ezrealty`.`smalldesc` AS `title`,
`#__ezrealty`.`id`,
`#__ezrealty`.`cid`,
`#__ezrealty`.`price`,
`#__ezrealty`.`locality`
FROM `#__ezrealty`
WHERE
`#__ezrealty`.`published` = '1'
AND (`#__ezrealty`.`language` = '*' OR `#__ezrealty`.`language` = {langtag})
ORDER BY
`#__ezrealty`.`adline` ASC
I try variations on:
SELECT CONCAT_WS(',', `#__ezrealty`.`smalldesc`, `#__ezrealty`.`locality`,`#__ezrealty`.`price`) AS title
FROM `#__ezrealty`
WHERE
ORDER BY
but no result.
Where is my mistake?
Logged
Well you should replace only the title line with the concat but leave untouched all the other fields, this is a correct query:
SELECT CONCAT_WS(',', `#__ezrealty`.`smalldesc`, `#__ezrealty`.`locality`,`#__ezrealty`.`price`) AS title,
`#__ezrealty`.`id`,
`#__ezrealty`.`cid`
FROM `#__ezrealty`
WHERE
ORDER BY
title ASC
Logged
Glenn Harper
I appreciate your timely and thoughtful replies. Sorry to be a dunce, but I copied and pasted the query you posted and I got a similar error to the times I tried my own queries. I set it to debug at http://todaysproperties.com/rockport-real-estate-sitemap but I'm afraid I still don't see the error in the query.
Logged
It seems that the error is a missing comma after the title at first line,
wrong:
correct:
Logged
