Re:Sitemap location (1 viewing)
TOPIC: Re:Sitemap location
#3372
Jürgen Ringel
Sitemap location Karma: 0
I've installed the jsitemap pro and submitted my sitemap successfull to google and bing. Till now, I was thinking the sitemap.xml has to be situated in the root directory from my site. Have I to export my sitemap and upload it to this place and have I also it to rename to sitemap.xml?
Thanks and regards
Jürgen
#3373
Re:Sitemap location Karma: 84
Hello Jürgen,
no you don't need a static sitemap.xml file at the root of your site. This is explained in more details at this FAQ: http://storejextensions.org/faq/when-i-add-new-contents-is-my-sitemap-updated-automatically.html
The sitemaps are generated dynamically, search engines are able to find the link for the sitemap through the robots.txt
