Re:Error Installation (1 viewing)
TOPIC: Re:Error Installation
#3476
wolf-media
Error Installation Karma: 0
Hi
joomla 3.4.4
just downloaded version jsitemap for joomla 3 and tried to install.
gettin error:
Duplicate column name 'meta_image' SQL=-- Exceptions queries in reverse versioning order 10.0 -> 1.0 ALTER TABLE `nemi3_jmap_metainfo` ADD `meta_image` VARCHAR( 255 ) NULL AFTER `meta_desc`;
and: Fehler bei der Komponenten-Installation.
s. img attached
Thank you
#3477
Re:Error Installation Karma: 84
#3825
webdesign-heindel
Re:Error Installation Karma: 0
hi, i got the same error by installing jsitemap pro. mightsites plugin isn´t installed.
anybody know whats wrong???
thanks and greets
#3826
#3827
webdesign-heindel
i´ve cleaned my database. There where rests of the older JSitemaps Installation.
Now i can install the new version of JSitemap Pro.
#3828
Yes probably on broken old installation was the problem.
Cleaning the database solves the problem indeed.
