Re:Jsitemap pro loads slow in backend compare to other components (0 viewing)
TOPIC: Re:Jsitemap pro loads slow in backend compare to other components
#3499
Allaboutwebservices.com Inc
Jsitemap pro loads slow in backend compare to other components Karma: 0
Jsitemap pro loads slow in backend compare to other components. Why it is so?
#3500
Re:Jsitemap pro loads slow in backend compare to other components Karma: 84
Hi Tony hope you are well,
if you mean only in the component control panel the problem could be due to the fact that the component open a connection to the remote server for the updater and version checking. In this case check if on the server PHP sockets and fopen are enabled.
regards,
#3516
Re:Jsitemap pro loads slow in backend compare to other components Karma: 0
Yes they are. The component loads fine and show the latest data. The only issue is with speed and time taken to load the component or show the data in it.
#3517
If you want I can send you a package without the remote version checking so that you can install and test if this is what consumes time.
Contact me directly by email for this.
#3544
Where can I get your direct email address? I do not see any option to send you PM on this forum as well as I do not see your email address in your profile of this forum.
#3545
