DJClassified and JSitemap (1 viewing)
TOPIC: DJClassified and JSitemap
#3597
Kuilderdkonsult
DJClassified and JSitemap Karma: 0
I am having a problem with djclassified and jsitemap
what I am getting is : http://www.swedishflyfishing.com/entries/accommodation/entry/22/103
and not the showing the record name. example : /classifieds/summer/summer-living/ad/camp-viking-bungalo,43
How to solve this?
thanks guys
#3598
Re:DJClassified and JSitemap Karma: 84
Hi guy,
all links generated by djclassfieds on your website are missing the record name/alias and are in the form http://www.swedishflyfishing.com/entries/accommodation/entry/10/45
This is how the router of djclassifieds formats SEF links but has nothing to do with the sitemap. Eventually you need to contact developers of djclassifieds and ask why the alias is not included in URLs, maybe they have an update for the router.
Best regards,
#3599
Kuilderdkonsult
Re:DJClassified and JSitemap Karma: 0
When I use XMAP then I get /classifieds/summer/summer-living/ad/camp-viking-bungalo,43, is it the router issue?
#3600
Not sure what you mean but this link is not ok at all and probably throws a 404: /classifieds/summer/summer-living/ad/camp-viking-bungalo,43
That's not the same of DJClassifieds, links in every sitemap must be exactly the same of the links of your website by DJClassifieds.
If the old plugin for Xmap build links in its own way that's wrong.
#3601
Kuilderdkonsult
Correct, before I used JSitemap I used XMAP and the link you see is an example,
have a look at this link is public http://mattjatten.com/vaelj-en-produkt/item/5-wilton/39-nice-beige as you can see it shows the menu name ,cat name and number as well as the product name and number, using XMAP.
#3602
The question is not related to the extension used to generate the sitemap, but to the routing done by DJClassifieds.
All links generated by DJClasifieds on this other site http://www.swedishflyfishing.com are in the form visible in the screenshot below, without any SEF alias.
