Re:create sitemap with joomla smart finder db? (1 viewing)
TOPIC: Re:create sitemap with joomla smart finder db?
#3627
BARRY
create sitemap with joomla smart finder db? Karma: 0
i have a component (comdev's jomholiday) that has a smart search index plugin, but no jsitemap support.
would it be possible to include items that are included in the native joomla smart search function in to the site map as a way to grab content from many non-supported components?
#3628
Re:create sitemap with joomla smart finder db? Karma: 84
#4938
Rowan Hoskyns Abrahall
Re:create sitemap with joomla smart finder db? Karma: 0
Also looking for jomholiday integration.
Will you be creating a source for this?
If not how do I go about it?
#4939
there is already a JSitemap plugin to integrate with jomholiday component.
Look at the download area for JSitemap, under the folder 'Data sources plugins for third-party apps' and you will find the JomHoliday plugin.
Take care that it's a JSitemap data source plugin and NOT a Joomla plugin, so install it in JSitemap as a plugin data source through the wizard, follow PDF docs if needed.
