Re:Failed in saving links when doing pings (1 viewing)
TOPIC: Re:Failed in saving links when doing pings
#3634
biz-online.hk
Failed in saving links when doing pings Karma: 0
After upgrading my server, the Ping-O-Matic Links not working in some of the URL links.
A screenshot is taken.
May you advise what goes wrong?
#3636
Re:Failed in saving links when doing pings Karma: 84
the problem is not the server, the problem are characters not accepted in the URL so not validated. It looks like you have chinese characters in the URL pinged that is not accepted.
I'm not sure if we already talked about this in the past,
#3638
biz-online.hk
Re:Failed in saving links when doing pings Karma: 0
John Dagelmore wrote:
I remember now.
Here was your message long time ago
QUOTE:
Ah ok now i understand! You referred to the validation of URL in the Pingomatic links.
This can be easily changed, by default URLs are considered as not valid by PHP and URI formats when containing UTF8 characters, for this reason the validation fails.
Contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it and i will send an updated package allowing transliteration of UTF8 urls to allow validation.,
Do you still have this " updated package allowing transliteration of UTF8 urls to allow validation.,", I think I need an latest update version of this.
Million thanks
#3639
I remember too.
Answered you by email Seth.
#3859
biz-online.hk
Hello there I get this error again after upgrade to JSitemap PRO 3.8.
It seems the changes were not included in Version 3.8.
Psl see attached screen.
My site info are the same as below.
May you have me check again ?
#3860
Hi Seth,
this was merged in the version 3.8 otherwise this would have been a neverending story
BUT it's under a configuration parameter, as visible below the resources management must be set to 'Server mode' to follow settings on your server.
PS: among thousands of users it seems you are the only one with this problem
